"Cant edit Ztool"
Hi all,
Here is a problem I am facing…I cant edit or modify mesh which is been saved as Ztool.
Here what I did.
  1. I started sculpting a mesh imported from 3ds max with uv layedout.
  2. During mid process I realized some UV has to be fixed.
    So I exported the mesh as lower division from zbrush to max, edit uv layout then again imported
    in zbrush .
    It asked dialog box to transfer data to highres , which is ok
  3. I add more details and finish sculpting and create all maps. Save the mesh as Ztool.
    Close Zbrush.
  4. I open again zbrush and load tool that mesh , but when i go to edit mode pressing T
    and apply some more details it does not effect anything on the surface.
What I am doing wrong here ? Will be glad to get a reply.
Thanks
A.S
probably masked.
tool.masking.clear
see if that gets you where you need to go
Thanks for info, Yes I had a look on that post …Solved now.
Thanks once again…
It could be masked as was suggested. Sometimes happens accidently. :wink: Are you trying to sculpt or paint/texture? IF there’s a texture applied you’re going to hit a roadblock with polypaint right there.
Hi Doug,
Yes it was mask problem … Only will sculpt it…
later paint…
Thanks
A.S
