Greetings. I’ve had this happen twice in separate files and can’t seem to find the issue. In both projects I did used Projection Master several times and at some point during the process, Zbrush seems to have locked the mesh or the UI into a non-edit mode. The only thing I can do is transform the mesh or do additional Projection Master edits. I can also mask. I’ve not dropped a new mesh or saved it and opened it as a doc or anything like that. I can move through the subtools and everything as normal, but I cannot paint or sculpt the mesh in any way.
Any ideas?
