I’m kind of new at this, trying to create my first complex model using layers. I’ve found that, as i create new layers on my ztool, I can no longer edit or even select any of the previous ones. I can turn them on or off, no problem, but I can no longer draw on them. I understand that there can only be one active layer at a time, but I can’t seem to pick which layer should be active. it seems only the last one created can be active.
What am I missing or doing wrong? This can’t be the standard behavior. At first I thought it must be some kind of file corruption, so then I tried it with a simple sphere with the same results.
I’m using Zbrush 3.2 with MacOS 10.6.1.
