Oh gosh… I am not good at this part. I purchased a subscription and I really should have checked this part out first.
my specs are :
processor: AMD A9-9425 RADEON R5, 5 COMPUTE CORES 2C+3.10GHz
12.GB RAM
my specs are :
12.GB RAM
Hello @JFinneman333
These are the official technical specs required to run ZBrush. Exceeding the recommended specs would produce the best results. There is no expectation of ZBrush functioning at all if the machine is below minimum spec.
While you have enough RAM to operate ZBrush, I’m skeptical of your CPU. Many notebooks are not going to be powerful enough to run high end graphics applications very well. I can only suggest trying it, and seeing what kind of results you get.
A nice thing about subscriptions is that they can be cancelled, so you won’t have to keep paying after the current billing cycle if you’re not currently in a position to run ZBrush to your satisfaction.
Good luck!
thank you! I went ahead and downloaded to see what would happen. So far so good! But we’ll see how the day goes.
have a good one!
