Can I slect manualy POLYGROUPS ? (color polygons)
Hi… just to know
Can I, manually, select the polygons for each group?
to make my own polygroups (COLOR POLYGONS ZONES).
picture attach
Defining polygroups is usually done with a combination of using the mesh visibility functions:
http://docs.pixologic.com/user-guide/3d-modeling/modeling-basics/mesh-visibility/
and the Tool > Polygroup > Group Visible command. Hide everything you dont want, and group the visible polygons. There are a number of other commands in the Polygroup menu that can be useful in different situations to create polygroups.
For low-poly meshes, you can also use ZModeler with the “Polygroup” operation to manually assign the selected target to a polygroup.
