I see where it says I can “reset all brushes” but is there a way to just reset a single brush back to it’s default settings?
Thanks
Thanks
Not directly but the default brushes are in the ZBrush 4R6/ZData/BrushPresets folder. Using the Load Brush button at the top of the Brush palette you can select any of the ZBP files in that folder. This will create a new instance of the brush, with the original settings.
Thank you Marcus.
