Can I export normals from high subdivision details?
Is there a way I can turn the detail in the highest subdivision of my mesh, into a bump or normal map? Then export a UV? And then just export the low subdivision / low poly mesh into the renderer, and simply apply the map? So that I have a nice low poly mesh with the normal map applied when I render?
Just a theory. but wanted to know if it’s possible. Its gotta be.
