im curious as to wat it can do with no other programs to assist it, as that is wat ill be doing if and wen we get it
If you look through my user gallery you can see work that I did that was 100% zbrush.
There are a lot of people who only use ZB. Mostly I try to avoid to post a rendered picture made in another program. I still work with ZB2 (Mac) and it is the best to use for detailing and a fast render. Mostly I need C4D to make the base mesh because it’s more easy, if you work on a Windows machine, maybe Silo or Modo are a good start to use in combination with ZBrush. The renderings made in ZB can give almost the same result like a render in another program but you have to make more, and bring them together in Photoshop. There you can play with it to get the best out of it.
ZB is good 3D program to use for illustrators, it’s like a kind of Photoshop 3D. But if you like to render industrial designs, you better can take another program.
I just did this in ZB3…
–E-- how and where did u get the texture for that zombie , and nice work btw
OK,the islands in the “Dutchman” Pic 100% Zbrush…sky is not.
“Pirates Flight” finished pic…vines added in PS but come to think of it I could have done it in Zbrush.
“Smeat” 100% Zbrush, Back ground PS
“Seahorse” the smaller seahorse is 100% zbrush…the rest is PS.
These are all quick studies…oh, did I mention none of these are 3D. This was all done in 2.5D…all pixol.
Some neat stuff can be done in Zbrush with a lil technique and some imagination.
Jet Olaño aka PixelFist
“…if I was any good, you would have heard of me by now.”
