Can a insert mesh be a different polygroup autoaticaly when using multipel times
If you are using for example an insert mesh of a button on a coat.
And you want to insert four buttons, it seems that Zbrush will make all four of those buttons part of the same poly group.
Is there any way to set up Zbrush to make each button an individual poly group automatically?
Thanks
Not that I know of but all you need to do is press Tool>Polygroups>Auto Groups. This will create a polygroup for each separate piece of geometry.
Thank you for that reply Marcus.
Yes I see Auto groups would do it.
My insert was it self made of two poly groups, so my solution to regroup them as one was,
to have Mask insert on then after inserting run a macro with these two commands : Inverse mask then, Grouped mask clear mask.
Good solution! :+1:
