Hello, I am coming to you because I encounter a problem quite regularly on zbrush 2020.
When I try to save my project, the software tries … And ended up quitting without saving, and without even having Quick save.
This tells me that Zbrush cannot save due to a problem which is most likely related to a corrupted file or an incomplete installation. But I have reinstalled the software several times, and downloaded several times as well. The problem is recurrent on all the projects that I have undertaken.
I asked myself the question and I mentioned the possibility of a hardware error, so here is the list of what is in my computer:
AMD Ryzen 5 1600X ( 6c 12t @ 3,4Ghz )
2x 8GB DDR4 Micron 2400Mhz
SSD M.2 SATA 256GB (os and saves)
NVIDIA GTX 770 4GB Gigabyte
Thank you
