Do you know how to put some buttons on a palette?
Like the PowerOf2 script from Aurick (without source, of course), who put some button within Texture palette.
Thanks in advance.
cameyo
Thanks in advance.
cameyo
Hello cameyo? Is it you? Good to see you here! I hope you have returned!
You use the ISubpalette command, just like you would for a plugin. You can even place a button over an existing one this way, as TVeyes does in one of his TinyToolz.
[ISubPalette,Texture:cameyo]
[IButton,Texture:cameyo:abutton,"What this button does",
//commands...
[Edit: you place the zsc file in the StartUp\ZPlugs folder.
Hi Cameyo,
Take a look at this thread. ZScripting new controls into ZBrush interface?
Just use the IsubPalette command to create a subpalette within an existing zbrush palette.
Thanks my friends!!!
I’m very happy…
to hear you.
I make a wrong question…
I wish to known how to put a button not on a palette, but within a popup, like the CropAndFill button within the Texture popup
Thanks again to MarcusCivis and TVeyes
cameyo
Ah, I don’t know how to do that, or even if it is possible.
TVeyes?..
I don’t think it is currently possible. I am not sure but the IDialog command might have been intended for such a thing, unforunately it is not functional in Zbrush 2.
Does the Power of 2 zplugin insert buttons anywhere else but the texture palette? I could not find any.
I’m sorry, the plugin of Aurick do not insert any button in popup, it’s a my error…as always
Thanks.
cameyo
Yes, PowerOf2 only inserts those six buttons into the Texture palette itself. I don’t believe that it is possible to insert buttons into the thumbnail popups.
Pilou
