Hey there!
I’m having some troubles using bump maps and deforming with inflate.
As you guys can see, here’s the visualization of bump map (of jeans) over an object.
The scale isn’t uniform, the calculation of different depths is very weird and the inflate deformation varies on what position your object is. As you can see, the result differs between image 01 and image 02.
The normal maps are all messed up
