Brush Size problem
Hello,
maybe it’s a bug : as I work most of time with big size pictures, I need big brushes. So, I set “Max Brush Size” to the maximum (will the size will be able to go higher one day ? should be nice). I save my interface and when I restart Zbrush, all my settings are OK, including the “max brush size” in the preferences that is set to 512 BUT I can’t increase the brush size over 128. I must, every time, move the “max brush size” slider from one or two units and after that I can go over 128.
Sorry for the length of this message but i’ts maybe a bug.
work on ahtlon 2.2 Ghz, winXP, Zbrush 1.55b, 2 Go RAM
Cédric
Yeah… sure looks like a bug. I just increased my brush size yesterday, but I hadn’t got around to playing with it. I had to play with the slider four times before I could get it to give me 512.
Also- the color of polyflame isn’t saved either, which is annoying, because I’m a big fan of changing it :slight_smile:
