All of a sudden the bracket [ ] keys don’t adjust brush size anymore.
Any suggestions on fixing this?
The buttons are in the ZPlugin>Misc Utilities menu, named <<Brush and Brush>>. Ctrl+Alt click on a button and then hit the relevant hotkey to apply it. Then press Preferences>Hotkeys>Store so that the changes will be available every time you start ZBrush.
That fixed it, thanks a bunch!
i have r3 and i dont see that menu
thank ya very much!
I’m having this same issue-
When I ctrl+alt on the focal shift or draw size slider it just changes the hot key from S and O all I want to do is size my brush up and down like photoshop. The weird thing is I have this same version at work and the brackets work fine!
The only difference is I have a 24HD cintiq at home…could that be the problem, a conflict with the cintiq?
Link doesn’t work, and I’m suffering from the same problem. Could really use a hand on hot to fix this, as its driving me nuts not having the size linked to the bracket keys.
Look in the ZPlugin>Misc menu, if you have buttons called <<Brush and Brush>> then re-assign the bracket hotkeys to them by Ctrl+Alt clicking a button and then pressing the hotkey.
If you don’t have those buttons then see here:
http://www.zbrushcentral.com/showthread.php?168102-Zplugin-gt-Misc-Utilities-gt-Brush-Increment-doesn-t-excist&p=947458&viewfull=1#post947458
