Sometimes the brush menu and alphas menus will appear at the top of the screen with no way to move the menu down or select a brush/alpha. How do I fix this?
Hello @Craig1 ,
This can happen if ZBrush is being displayed on a screen that does not meet the recommended resolution requirements. Keep in mind that any active display scaling coming from the OS may also functionally reduce the display resolution for the purpose of displaying ZBrush below recommended spec, even if the hardware’s native res would be adequate.
In this case you can reduce the size of the UI elements to fit more of them on screen by using the Preferences> Interface> UI> Button Size function slider. Adjust that downward until you can more easily fit the pop up menus on screen. You will need to restart the program before you see any change from adjusting the slider.
