Is there a way to import a obj and remesh it in ZB so it can be re detailed? Any help would be fantastic!.
Steve
Steve
Hi @swpropmaker
You can import a number of different formats, including obj., through the Tool menu’s Import button. You can then use ZRemesher to remesh it then subdivide and sculpt as needed.
http://docs.pixologic.com/features/main-features/import-export/
Hi Steve,
looks like that the polygon normal’s of your obj model are not ‘even’ aligned.
You could check this if you activate ‘double’ in the display properties.
http://docs.pixologic.com/zbrushcore/reference-guide/tool/display-properties/
If you can see the full model then it’s a ‘polygon normal’ problem.
I’m not sure how you can solve this in ZBrush, maybe to dynamesh the model with a corresponding high resolution.
Perhaps a more experienced ZBrush user has a better idea.
Edit: I searched with google and found this fast and simple tutorial that maybe could help.
CU and good luck.
