Hi.
I need to be able to 3D print some ‘Braille’ labels for a zoo project and am having some problems. I modeled a ‘tag’ blank in Maya with a Boolean hole but the resolution of the ‘hole face’ does not allow for a clean import into ZBrush. The hole is a quadrangle after import. I need to either add resolution to the faces in Maya before the Boolean operation or I need to perform the Boolean in ZBrush. I have not been successful in adding resolution in Maya because the ‘Insert Edge Loop’ tool will not sub-divide the required face. It only subdivides down the sides.
How can I use Maya/ZBrush to accomplich my goal?
Thanks!
~T.~
Tim Lawrence
ConservationArts.net
