Hey guys, i`ve been cooking up this script over the last week to speed up bpr pass creation
You can get it on gumroad for free https://gumroad.com/l/yJVG
Very good idea! It will save a lot of time . Another thing that could also save time would be an action for Photoshop to create a base composition with groups alpha channel etc… Then you would only need to tweak it.
There was this >> http://www.zbrushcentral.com/showthread.php?94752-Useful-small-ZScripts-and-Macros-for-ZBrush-4.0&p=907347&viewfull=1#post907347
This could be useful perhaps>> http://www.zbrushcentral.com/showthread.php?187894-White-in-rendered-BPR_Mask-PSD-files-is-not-R-G-B-255-255-255-Solution
oh cool! such a button was my first idea but i imagined i`d expand on it a bit and make the process of capturing different lights and materials a bit quicker
That script is a great idea , i might adjust it to process an entire folder of passes and nicely setup the entire PS structure for each capture
thanks for the links
Thanks Doug and Marcus. I missed these zscripts
This is free or not ?
I can´t get the script from gumroad ?
You have another link ?
Thumbs up Leslie, thanks for sharing!
Hope life in K-lifornia isn’t too much of a burden
This is a Photoshop script that Organize all different layers coming from “BPRBatch” (Polydrawer).
!Read/look the Manual before using (HowToUse_BPR_CS_Organiser.jpg)! (Should work from CS3/newer versions)
DownLoad:
Is there a chance for R7 x64 compatible version?
Awesome script! Us mac guys and gals would love to join in on the fun! Are there any fellow Zbrushers out there who could lend a hand on how/where to install this timesaving plugin? Thanks in advance for helping this noob.
Just wanted to pop in and say THANK YOU so much for the share. This is incredibly useful.
Also thanks to TreeSnake for sharing the PS organizer. That is a must have with this plugin.
Amazing plugin, Is there any 4R7x64 compatible versions out there >.< Would love to use in x64 with the BPR CS Organiser too
It works with the 32 bits. But I can not see how too control the intensity of the lights. The indirect and rim lights are way too weak to be useful.
Has anyone been able to get this plug-in to work in 4R7? When I install it, ZBrush will not start; it hangs and has to be forcibly shut down.
Chris
