bowling
Strike ! :cool:
Pilou
Andre, looking better then good, looking great.
Now if this were mine, I would inflate where a kinda suit goes and inflate where a tie goes, make the suit black (whatever color), so these guys who are left standing in the bowling lane, if they go down from the bowling ball, they are fully dignified :smiley:
Something about their face demands dignity :smiley:
And they have it standing :slight_smile:
Love it, and the whole concept.
Mandy
I know people here get excited by heads and yours lately here have been tops.
But the perspective here is I believe great.
Too many images look flat like paintings or sketches.
This is truly 3d.
You get the feeling, I like it?
This has depth, which in most mediums are hard to do.
Post!Post!Post!
Andresloy, would like to steal from you.
In the work I just posted trying 2, I was lucky with the glass and worked my ass off on the robe. But it is basically flat, the only implication of “dimensions” is the sharp of glass with blur of robe.
If I could “force” the perspective to put that scene at the other side of the room it would work( have to color walls, another window maybe etc) I could then justify to the visual senses no face( YEAH?!!)
Now.
Can you tell me how you did the walls,
Planes?sketch,I have seen someone remove the side of a rectangle and make the inside a “enclosure”
Can you tell me how you did yours?
Thank you
Post!Post!Post!
Very creative work Andre! I think kitty has a
point there, though i would settle for black,
not very long ties! :wink:
I must confess. I love the subtle reflection of the “bowling pins” on the floor on the left wall. It adds a lot I think, and it does not detract from the center of your work.
Mandy
Thanks for the kindly feedback and also thanks for the suggestion…i will try to do some in that direction¡
Hi rtyer I made a script to you showing to way to make the wallls, both use 3DCube
a.-Put the 3DCube in the canvas in edit mode, unpress SH and SV, then selected the white rectangule alpha 00.0 and press crtl and cut one face of the 3DCube and press hide pts in selection panel…
b.-Put the 3DCube in the canvas in a way it cover all the canvas…and center it the press snapshot object and press Zsub and you have your box in perpective. Carefull in both 3dCube you must press shift and perspective and centered in the best way for you.
All this bad explanation is better see it in the script.
rtyer perspective.TXT
and this was the image a created for the example.
I hope this help if not please let me know¡¡
Thanks for your attention
Andreseloy
Well done Andre! :slight_smile: :+1: :+1: :+1:
Hi DeeVee a pleasure to know about you¡¡¡I hope everything is fine for you and your family¡¡¡
Andreseloy
Thank you andresloy,before I begin it one important question. Can I texture basically each of the three walls separately.
I want the image to be on the far wall and have each side wall with differect color and window?
Any advice most welcome, thank you for your help so far.
Post!Post!Post!
Very cool idea and images–nice departure–and good forward creative momentum !!
Thanks Robo for your feedback and also rtyer¡¡
Here is another script about how did the image below I hope this could help you rtyer¡¡
Let me know if it work for you¡
Thanks
Andreseloy
RTYER PERSPECTIVE II.TXT
ps: i was reviewing the script i does not work very well (it happen to me every time i use global perspective) but anyway it show you clearly the way i made that image)
excuse me for that
Never, repeat, never excuse or apologize to me for anything!
You and others have helped me since the day I started here.
Very often the difficulty is double on your end because you are helping in a language not native to you
You have been supportive,kind and patient.
It is I who must apologize to you for interrupting the showing of your work to answer my stupid questions.
My thanks as usual
Post!Post!Post!
Without interruptions.
Ran script, got the principles, I hope.
Thank you again for the time and effort involved.
Hearfelt gratitude!!!
Post!Post’Post!
Andrè, please - consider this:
you had a picture in your mind, and you were able to bring it out. Now, these are YOUR figures, you saw them first. Somebody may take them as penguins, some may take them as parts of a bowling game. That’s quite allright - but: if you change them according to the perception of the viewers: you will be busy for a long time, and each time yo alter this pic you’ll loose that important bit of yourself.
What I mean: please don’t limit yourself to the views of anyone! It is yours alone, and: if ten ppl can see ten different things in your pic >> how much better can a pic be!?
I simply like your pic the way it is, even if it may not fit into one of my personal drawers. :+1: :+1: :+1:
