Hello,
I have put down polypaint lines in Scultpris Pro mode onto a model. Whenever I try to use the PolyGroupIt by polypaint command, the resulting polygrouping is very unsatisfactory as the painted borderlines become polygroups themselves, although the borderless option is used - Could this be because the line is too thick? I am painting with a brush size 2/3 and the model has a little higher than low polycount. Is there an option to work around this or is it supposed to happen like that? In all the tutorials the Polygrouping seems to work flawlessly.
Thank you and best regards
