Hello
Can you please tell me if it is possible to make a boolean operation with ZBrush? If yes how?
thanx
Hello
thanx
Hi Yazal,
have you checked out the Quick Links section? There you will find plenty of info on ZBrush. Also, if you haven’t downloaded the manual, you may want to do that; a good starting point (unless you are like me… learn by poking around with the software
)QuickLinks
Look for “Downloads”
ayayaye, I will not sleep with all those documents.
:eek:
Thanx
ZSUB and ZCUT in the Draw palette act similarly to booleans. BUT while you can create a multiple marker object that uses those draw modes, you can’t convert it to a mesh.
A multiple marker mesh uses ZADD, only.
