Boolean Cutter ZBrush function suggestion
I was wondering if someone could create a script, or — even better — if the Pixologic developers could add a ZBrush function to do this:
1: Draw a shape in front of an active subtool, using any of the strokes you can use for creating slices and masks, such as the lasso stroke, circle stroke, etc…
2: The drawn shape is then extruded into a mesh that extends through the active subtool.
3: The extruded mesh is subtracted from the active subtool using Live Boolean.
For a script I guess a possible way to go might be to use the CurveTriFill brush to create the shape, then extrude it, assign a Group As Dynamesh Sub to it and use the Remesh By Union deformer. The disadvantage of this route is that you have to rely on drawing with a ZBrush curve for the CurveTriFill brush, in stead of being able to use the different strokes.
Many thanks in advance.
You can extrude the masked area with “Extract” function, then use that for the boolean.
Thanks for your reply. That’s a possibility indeed, but it requires many actions. Each time you want to make a cut you’d need to create a plane in the view’s orientation, subdivide it, draw a mask on the plane, extract or extrude the mask, activate Live Boolean, create a Boolean mesh, append the result to your active tool, etcetera.
It’d be great if you could draw arbitrary and precise cuts through a subtool simply by using one of the available stroke types.
For inspiration here’s a video about a free add-on called Carver MT that’s included in the Blender release.
