Bevel Pro not working
Hello
Im using Zbrush 2022.0.5. When I’m trying to open bevel pro white window is popup and then disapear with “operation canceled” info. Anyone experienced same problem? I even reinstall zbrush, try diferent subtools, low or high mesh and nothing works. I’m using rtx2070.
Hello @Alterart
Please contact ZBrush Support for technical issues with ZBrush. The other users in the community Usage Questions forums won’t be able to help you with system specific technical issues, and we can’t provide technical support over the forums.
I’m going to close this thread to eliminate any expectation of further assistance here, and to encourage you to go where you need to in order to get help with your problem.
Thank you!
