This critter was sitting on my hard drive for a while, finally got around to rendering up the top view. Some sort of alien poison dart frog type creature that has the ability to glide from tree to tree, this guy is a bit smaller than the green variant and also has a thin membrane between his back wings to help glide/maneuver faster to evade predators. Will be doing a more elaborate rendering of the design soon posed on a branch or something so you can see it in a more dynamic view, or maybe a grey render to show the form a bit more clearly? Similar to other creatures in this world it sees its surroundings with some sort of sonar type pulse, the head is some advanced almost completely circular disc type form, almost like the big radar dishes you see on AWAC***8217;s, so this little guy has a very clear picture of his surroundings from 360 degrees while it is in the air.
A bit hard to see the design with the poison dart frog paint-job so here was the unpainted block-out of the model. So now you can more clearly see the almost completely circular disc type head form, like the big radar dishes you see on AWAC’s…but organic! Will detail him up and make a bit more sense of the design… front wings that are in contact with the ground need more thought and some sort of appendages need to be worked into that area before i believe that this thing could grip onto trees/objects inbetween gliding (have a few thoughts of integrating some sort of frog finger/pads near those two points close to the head). Will try to work all that out before i do the more dynamic pose/render later this month after i wrap up some
freelance.
Vehicle from a project i worked on beginning of last year, just got clearance to show this design. Probably the first vehicle i tried to visualize in 3D to show a Director what i had in mind…then i never looked back, powerful stuff! Lot of things i would do differently now on this from a design/rendering standpoint, but was a fun project to be involved with and look forward to see where it goes. Hopefully much more to show later this year, stay tuned.
And here was the Zbrush block-in i used for the paint-over.
