贝恩的速雕,想让他更有一些监狱风格
终于把Zbrush 缩放大师弄明白了,但是好像Zbrush2026里缩放大师没办法以cm调整模型,不过仍然可以用mm调整,所以依旧没问题
A quick sketch of Bane fanart
I want to lean on prison thug type of character
Finally figured out how to use scale master,but something wrong with Zbrush2026 scale master,it seams like i can only adjust model in mm instead of cm, but everything works out in the end
姿势参考自 Ivan Pavlisko
pose reference from Ivan Pavlisko
www.artstation.com/artwork/oJw2AL
