Axis Indicators \ Geosphere Object
I would like to see axis indicators diplayed in order to show the top and bottom of the 3D sphere…sort of like a north and south pole. This would enable me to see where the convergence is without turning on the display of the wireframe mode. Funny thing is I haven’t even found that wireframe mode function yet.
Do you also have any plans to make a Geosphere object. The above axis indicators would be a really handy feature for this object as well because you would have to know where the initial mapping coordinates would originate from (in some circumstances).
Plus…a sphere based on a triangle face structure is more flexible compared with an object with quad faces isn’t it? It would seem that the traingles do get distorted when you sculpt an object so that might not matter either.
Thanks.
Jody Rusnak
To display the top and bottom of the sphere, turn on either Transform :small_orange_diamond:Move, Transform :small_orange_diamond:Scale, or Transform :small_orange_diamond:Rotate, and make sure that Transform :small_orange_diamond:EditObject is off. The gyro will appear over the object. Look for where two rings intersect, that shows an axis.
And to turn on the Wireframe, first turn on Transform :small_orange_diamond:Quick, then turn on Transform :small_orange_diamond:Pf.
