I am having problems setting hotkeys after upgrading to zBrush 2018. I am trying to config zBrush so that “.” is the hotkey for increase brush size. I add this to the startuphotkeys.txt file:
[ZPLUGIN:MISC UTILITIES :BRUSH>>,46]
But when I restart zBrush, the GUI reports that I’ve configured the DELETE key, which is obviously wrong! If I try to set the key manually through the GUI, I get the message that “Custom hotkey is not assigned to this item”. This worked fine in zBrush 4R8, as I recall, so I am wondering if anyone else has this problem in 2018 - or if anyone could check if they’re able to assign “.” to anything in the GUI?
