Hello peoples,
I have been modelling a fairly high poly light fitting as a segment to be glued together with an array mesh, originally modelled in high detail at about 4 million polygons and decimated down to about 100K for a hopefully all up count of under a million polygons for the entire array object.
Im having a problem getting the array mesh to weld the polygroup edges, both sides of the object are grouped to one single polygroup edges, but it just doesn’t seem to want to do it. Are there any limitations to the polygon count for array mesh when you doing such a process ?
I’ve attached a pic with an exaggerated gap that I need to close, if anyone has any ideas why this isn’t working please let me know…
Cheers
Adam
