Hi Guys
Just looking in to Building a new PC for some Zbrush, Max, Maya and Photohop use.
Here are the specs I have sorta chosen from a PC building site.
CPU: AMD FX-6300 3.50 GHz Six-Core AM3+ CPU 6MB L2 Cache & Turbo Core Technology
MEMORY: 16GB (4x4GB) DDR3/1600mhz Dual Channel Memory [+74] (Kingston HyperX Blu w/Heat Spreader)
MOTHERBOARD: Gigabyte 78LMT-USB3 AMD 760G Chipset DDR3 Socket AM3+ Micro ATX Mainboard w/ 4 RAM slot, 7.1 Audio, GbLAN, USB3.0, SATA-II, 1 PCIe X16, 1 PCIe X1, & 1 PCI
VIDEO: NVIDIA GeForce GTX 650 Ti 2GB 16X PCIe Video Card [+79] (Major Brand Powered by NVIDIA)
CAS: CoolerMaster Elite 310 Mid-Tower Gaming Case w/ Side Panel Window
CD: 24X Double Layer Dual Format DVD±R/±RW + CD-R/RW DRIVE.
CS_FAN: Default Case Fan
FAN: Asetek 510LC Liquid Cooling system w/ 120mm Radiator (AMD) (Asetek CPU Water Cooling (AMD)
HDD: 1TB SATA-III 6.0Gb/s Cache 7200RPM Hard Drive (Single Hard Drive)
MONITOR: 22" TFT Active Matrix LED Display [+74] (22" (21.5" Viewable) Wide TFT Panel Black 1920X1080 5ms, D-Sub, DVI)
NETWORK: ONBOARD 10/1000 NETWORK CARD
OS: NONE - FORMAT HARD DRIVE ONLY(NO OVERCLOCKING AVALIABLE)
POWERSUPPLY: 500 Watts Power Supplies [+25] (CoolerMaster Elite 500watt Gaming Power Supply)
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
USB1: Built-in USB 2.0 Ports [+0]
Good or not good? Anything I would need to change because it isnt powerful enough?
Any suggestions much appreciated.
