Appending Subtool Drastically Changes Scale
I’m having trouble controlling or predicting the size of appended sub tools–they sometimes append to the tool at ENORMOUS scale differences (where they can’t even be viewed together) and trying to rescale them often crashes ZBrush.
I want to create a series of figures and tools that all relate in scale (so I can interchange heads, parts, etc.) but I have no idea how scale works in ZBrush. Is there a way to standardize the size of my tools so they are compatible with each other? And is there a reason that tools that seem to be comparable in scale (based on the view when I toggle back and forth from selected tools) still append to each other at incompatible sizes? When I try to adjust one tool to the viewing size of the other, that doesn’t seem to predict the size it will append. I’ve wondered if the document size is affecting the tool size, but haven’t found a solution. Thanks for your help!!
tool > deformation > unify all subtools then size - position
I always use Subtool Masters Multi Append tool for adding new meshes. I find it does a good job setting things up so that scale is maintained inside of zbrush, and when sending objs back and forth to other programs.
Thank you so much. These are both very helpful suggestions that my own measly brain would never have discovered!
