Anybody else having trouble with Trim and Slice Rectangle in 2021.6.3
I just did an clean install upgrade to 2021.6.3 , and found that the Trim and Slice Rectangle brushes are not working. Any body else experiencing this? or can suggest why?
All the other slice, trim, clip, and select brushes are working.
I was using the trim rectangle all the time in 2021.5 no problem but now with 2021.6.3 it does not work?
Thanks
Hi @Zolly , it a known issue , it has been reported so the dev team is aware about the bug, and hope a fix will come as soon as possible.
Hope it helps!
Nicolas
The development team is aware of the issue.
Thank you everyone!
