I’ve been using ctrl + combinations for alphaimage shortcuts in Zbrush3.5
when i press the ctrl key in Zbrush4 it turns to MaskPen . So i can’t assign
Ctrl + shortcuts
Does anyone know ?
Ctrl + shortcuts
Does anyone know ?
It’s CTRL + ALT now…
http://www.pixologic.com/docs/index.php/Note_for_Previous_Users
Hope that helps.
James
Thanks … but that’s not the answer i want to know…
(Ctrl+alt +Lclick) is assigning hotkeys , after that I want to Assign Ctrl+ ( )
combinations for hotkeys…
Aah, yes, I should really read posts properly.
Sorry.
Try this:
Assign a different shortcut to the item and save your hotkeys. Open the hotkeys file and edit the shortcut to replace the saved hotkey value with the desired one.
To get the desired value, open the Preferences>Utilities menu in ZBrush. The second slider in the menu shows the value of any keypress or combination. Hold Ctrl+Whatever and note the value shown. Then put that in your hotkeys file.
Thank you aurick I didn’t know about Keyboard status Utilites .
But it doesn’t work… As i mentioned Whenever i press the ctrl key
Brush changes to MaskPen… I want to change BrushAlpha images when i’m
using Standard Brush not using Maskpen . I hope you understand what i’m
saying…
