The ZBrush process tends to hang after a crash (or sometimes just after closing the program). If the ZBrush process is still running, you’ll get the:
"INTERNAL ERROR .\AFile.cpp Line:728
Unable to open/Create a FileC:PROGRAM FILES (X86)\PIXOLOGIC\ZBRUSH 4.0/ZStartup\Tempfiles\search.mem
I’ve tried using the taskkill windows command, with /F, /t, etc…and it says it kills the process just fine, but it never leaves my process window. Same with pskill (wasn’t sure what I was expecting, but figured I’d try)
I also don’t have access to the Tempfiles directory, because “a program” is still trying to use it.
And, of course, when I try to launch ZBrush again it says only one instance of ZBrush is allowed to be run from the same directory.
SO, since ZBrush isn’t a critical system process, why is it being so stubborn? Is it just my machine, or am I missing some sort of permissions to be able to kill it without restarting my computer?
