Alpha size?
Hi guys,sorry for the noob question,but when I’m using a brush with Roll option activated,there is a way to stamp a bigger alpha without the need of changing my draw size? The problem is that if I where to increase my draw size,I would also need to waste a lot of time masking the small portion I need the stamp brush to work on :confused:
I’m not entirely sure I understand the problem, but let me throw a couple things out there to see if they help.
  1. You can attach a Drag Rect stroke type to the brush with the alpha, which will allow you to drag out the alpha stamp as large as you wish without increasing the stroke size. I’m not sure how compatible this is with the roll function, but it sounds like you’re just trying to stamp an alpha into a small space.
  2. When trying to mask a target area, it isn’t necessary to mask everything but. Simply mask the target area, then ctrl-click on empty canvas space to invert the mask.
Thanks for the reply Spyndel,I thought noone did reply to this and just realized I had my notification turned off :lol:
