I’m a new user and I have got some problems with a custom alpha brush I’ve made.
I created a simple alpha gradient in PS (horizontal ellipse shape) and then saved it as a PSD (grayscale, 16bit, 256x256px). When I import it in ZBrush3.1 and start to paint then my alpha is only applied in the vertical direction… if I go back to PS and rotate my alpha 90 degrees (so that it gets vertical in PS) and then import again, it’s still only applied in the vertical direction?
Is there a setting in ZBrush that makes the brush stroke rotate, depending on how I use my Tablet?
I’ve attached a screen grab where green indicates how I want the alpha to be applied and red is how it’s being applied now. Hope you understand my problem. Thanks in advance!
// tennet
