hi all,
I have a little problem using the turntable plus plug in on zb 4R6.
When I click on the best preview render in the turntable plus options and launch my render, even if I check the alpha case in order to calculate the alpha, it seems not to render it as a separate image sequence, and it just renders one sequence of image with a black background.
Obviously importing these images in photoshop or after effect reveals that the black colour around my character is not an alpha.
If I don`t check the best preview button, the alpha is calculated as a proper image sequence, but the aliasing all around the character is a problem…unless calculating veeeery big images and reduce their size…
did someone have the same problem?
any solution?
thanks a lot
