Allign subtools to (one to another)? (How, if possible)?
I have two exact (except position, maybe rotation and maybe scale) objects (subtools) in zbrush.
The first one imported for some reason of the original position. I made changes to it already (via sculpting etc.) but it is off its original position (i dont have a clue why (!?) ). So i impored the original (unchanges/unsculpted mesh) and its has different position (maybe probably also rotation and scale) . Is there some (automatic) allign feature i can use (as is in 3ds max for example) when i can allign the first (accidently for some reason moved) sculpted mesh to the second exact mesh (with original - different position)?
You should be able to do it by copying the values in the Tool>Geometry>Position sliders from one subtool to the other. I wrote a plugin a while back which will copy/paste the values:
http://www.zbrushcentral.com/showthread.php?195599-Scale-Offset-Copy-Paste&p=1151204&viewfull=1#post1151204
Thank you will try it
