All zBrush saves loading wrong mesh
Hey guys, pretty big problem as the title says. Hopefully someone here has a fix.
I spent all day yesterday working on a mesh which began as this (terrible) base mesh. For some reason every one of my quicksaves and my own saves with this project load the base mesh.
As you can see from this image the data in the thumbnail definitely isn’t what is being loaded in.
Totally clueless with how to fix this, save me D: thanks in advance
I’d need a broader range of information here. Every time you try to load a quicksave, you get your base mesh as if there were no changes/edits? Right the same as you started with, before you began sculpting?
Check and double check SubTools panel for different subtools, File panel for tools or copies of tools you didn’t notice were there, Geometry for subdivision levels, Morph for, well, morph levels; check the project’s chronology in order to be sure you’re in your last chronological step.
Mesh explosions and load fails can occur, it is advisable not to forget progressive saves (saving project progressively in separate files).
