If you are using MS Windows, please use Windows update as soon as possible and at least apply the Security Patches (IE and Service Pack upgrades take a while and can be deferred)
The worm going around today is called MSBLAST – it affects Windows 2000 and XP (maybe also NT)
If you search your hard drive and find the “msblast.exe” file, please do the following:
Unplug from network
Start --> Run --> MSCONFIG and disable msblast.exe
Open task manager and end the msblast process
Delete “msblast.exe” from the folder where you found it
More-detailed info and removal instructions can be found at the major antivirus websites, e.g. McAfee or Symantec
EDIT: here are some links to more info:
http://us.mcafee.com/virusInfo/default.asp?id=description&virus_k=100547
http://www.symantec.com/avcenter/venc/data/w32.blaster.worm.html
Hope this helps,
Kevin
