After a right click on model to tumble, How do you tumble around models center.SOLVED
Ok another weird one from Susan.
If you use Clasic Zbrush navigation,
and right or left click off the model and drag.
The model tumbles around its center.
If you have Right click navigation enabled,
When you right click while the cursor is over the model and drag,
the model rotates around the point where you clicked while over the model.
And Zbrush resets the tumble point to wherever you right clicked over the model each time.
This new tumble point that you last clicked stays in effect even if you right or left click off the model now.
Heres the question:
After doing the right clicking over the model and tumbling around that point,
how can you set the tumbling point back to the center of the object again?
So that you can once again click off the model drag and tumble around its center.
So when your rapidly drawing you can quickly cycle between the two modes of tumbling.
I usually keep Right click Nav. on, It would be nice to click on the model spin it around where you clicked.
Then click off the model and spin it around its center.
Thanks again to everyone!
Crazy I know,who was it that said “shut up and paint” De kooning, I forget.
But we have these machines now we have to operate or do we? … yeah we do!
Its always the one button you didn’t try.
For any one interested this is a simple one, turn off local transformations to always tumble at models center.
F to Frame your object does the same
