[attach=208311]AdjustHeader.jpg[/attach]
Note: all plugins are now included with the ZBrush 4R7 installer. If you did not install a plugin then run the installer again.
For the latest information see the online docs here : http://docs.pixologic.com/user-guide/zbrush-plugins/
This plugin is for adjusting your Draw Size, Focal Shift and Z intensity settings without interrupting your workflow.
This plugin is available with ZBrush 4R6.
Installation
The plugin is automatically installed with the standard installation of ZBrush.
Frequently Ask Questions
Q: I don’t see Adjust in the ZPlugin palette.
A: If you did a custom install of ZBrush then run the installer again and make sure you install the Adjust plugin.
Q: The plugin doesn’t work. I press the hotkey but nothing happens.
A: Reset the hotkeys by Ctrl+Alt+clicking on the buttons in the ZPlugin>Adjust plugin menu. Store the hotkeys before quitting ZBrush by pressing Preferences>Hotkeys>Store. The plugin should then work correctly.
© 2010 Pixologic, Inc. All rights reserved, Pixologic and the Pixologic logo, ZBrush, and the ZBrush logo are registered trademarks of Pixologic. Various patents pending. All other trademarks are the property of their respective owners.
