Adding thickness to high res mesh?
I’m having an issue with a suit jacket mesh. If I add thickness with extract or create diff mesh, it adds geometry I don’t want in the lapel of the jacket. If I do it through the zsphere method of bringing in the topology and then using the thickness slider, then it works. The problem is that you can only bring in topology of up to 15,000 polys. I can’t add thickness to a lower subdivision because then I would need to project the details, which is almost impossible with thick meshes.
Is there a work around?
Can you show a screenshot of what you mean by “it adds geometry I don’t want” ?
