Can anyway tell me how to get the insert curve tube to follow along the entire path of the add to edge guide?
You can’t the way you are doing it because you have more than one curve. Between each red dot is one curve. That is why you are getting that result. A better way would be to use Frame Mesh.
I know the frame mesh feature, but that creates a closed loop( frame ) around the entire mesh. I just need a a single curve tube to follow the edge not frame the polygon. Can this not be achieved?
I had a feeling you might ask that. See the following images…
Thank you.
No problem! Thanks for the like.
