Some people have seemed a bit confused about how pixols and 3D objects work in ZBrush, not to mention what happens with cast shadows, so I thought I’d draw some diagrams and discuss it here. If any of my assumptions are incorrect, please do correct me.
About the Nature of Pixols
When you edit a 3D object it is fully rotateable. If you were able to view the canvas “from the side”, editing a 3D sphere in front of the canvas would look like this:
But what happens when you Snapshot a 3D object into the canvas? It gets converted into Pixols very much the same way a vector shape becomes Rasterized in Photoshop, with one exception: The depth information is still there. However, pixol depth information is “one-sided”, there is no “back side”. What it means in practice is this:
Think of the canvas as a computer generated landscape. Pixol information has no back side. There can be only one depth value per pixol, so within one layer, one pixol cannot be behind another - that requires a separate layer. Thus, once you’ve snapshotted a sphere into the canvas, it becomes a hemispherical dome shape embedded into the pixol canvas. On other words, it becomes a part of the canvas.
This also explains why the cast shadows look the way they do in ZBrush:
Due to the way they are calculated, shadows cannot be cast from one layer to another. Therefore the layers must be Flattened for rendering if shadows need to be present. And since Flattening combines all the layers into one, one pixol cannot be behind another, thus cast shadows and transparency are not possible within one scene.
If you want the objects to really look separate from the rest of the work shadow-wise, the ZMode can help you work your way around this. ZMode works by assuming that all “vertical surfaces” (ie pixols that are completely perpendicular) do not exist and are left out of the shadow calculation:
But since the pixol information has no backside, the ZMode shadows end up looking thinner than the visible top side would suggest.
When you 3D Skin an object, a similar procedure is made, but with one exception: The pixol data is mirrored, resulting a symmetrical 3D object:
I stand to be corrected.
I have a toy like that in my room as well.
