[sleep,10,[note,“this sleep command doesn’t work,why? help test it
the reason for this is i want to save a tool in 10 seconds, how do i make the sleep active in 10 seconds, i found it here http://www.zbrushcentral.com/zbc/showthread.php?t=18101
but seems the sleep work only on start up
Edit:
Ah, no I couldn’t get it to work either. Sorry.
Marcus
Sorry.
For me, everything except TIMER seems to work.
We need some input from the moderators, I guess. (PIX?, Aurick?)
Sven
I’ve done some checking, and found out the following:
The Sleep command is only active for the currently loaded ZScript. If another ZScript is loaded while one ZScript is sleeping, the Sleep command will be cancelled.
hey aurick, could you set up a sample using a timer and have it save some thing then 10 seconds later do some thing else using the timer like Svengali was asking?
