HI,I have an idea that the current text plug-in can generate bevels and then smooth the chamfers by adjusting the curvature options, but this feature works only with text models.
So I would like to ask whether this feature can be applied to other 3d models, because the current software does not choose the edge of the function.
I think if you mark the edges with the crease function, then convert crease to bevel and then use the curvature to get the chamfer.
This idea should be logically feasible.
Because crease does have a similar bevel function, but no curvature control options,
I was feeling a bit frustrated at the lack of chamfering in ZBrush recently when working on hard-surface cases, so I wanted to see if using a script could do that.
Thank you very much.
