Hi
I am not sure if it’s just me. Every time I turn the floor on and use some navigation I get the Abnormal termination message and crashes Zbrush.
Here’s what I do.
- Draw any cylinder or object.
- Press T(edit)
- Click PolyMesh 3D and turn on the FLOOR on (X,Y or Z)
- Press T again to turn off the edit mode and press W( Move)
- click or drag few times anywhere on the object
- Press T again to turn on the edit mode.
- Press T again to turn off the edit mode and Press W.
- If it doesn’t crash repeat from step 4. and make sure Floor is turned on.
I tried version from 4R6 to 2019. Only one that works is the 4R6 and others doesn’t work.
I am using windows 10 64bit.
Does anyone have same problem??
