Hi man,
impressive work here, super texture and mood!
If you have time i have some question for you:
> bumpmap feature is one of my favourite features in Zbrush
- I'm learning XSI 5.0 and i'm tryng to use Zbrush in my workflow.The question is: you create the UV in XSI and then export the obj and UV in Zbrush, or create and paint directly in ZBRUSH(AUV or GUV?).
- Is only a single UV?
- Which material have you use in XSI? > i didn't use displacement, all i used is bump map, i am a bit scared by the render taht XSI gives out with displacement map, i havent heard any quick and easy way to solve that
what kind of technique have you used?
If you are interested i’ve found a simple and easy workflow to obtein a Displacement. For me doesn’t work well when you have small and particular detail (skin or pores, in this case a bump is better)
