Ok there is a great thread below describing ram usage and memory settings, instead of hijacking it I am just starting another post.
Ok a few more performance questions.
I have ZB on a partition with other applications, it is seperate from windows. Now I have another partition where I store all my files models textures scenes… Will having the zbrush files seperate from the application be a problem.
Also I am getting out of memory errors and the displayed brush is not using anywhere near max memory or my setting what should I do? Could it be a max poly srtting. The error occurs when the brush goes from 1.6M polys to 6.7M. It does the divide, and will come back but then cannot be reloaded. Memory usage goes from 550M to about 1.4G … I set mem preferences to 1.9G and 7M polys.
Thanks for the advice,
James
