It has gotten so hot that I’ve gotten a thermal warning from my laptop, an Alienware 15. The 64 bit version also crashes anytime I use trim rectangle. I went back to the 32 bit version and haven’t had any crashes or overheating. Anyone else experiencing a similar problem?
Try running the MultithreadingOptimizer in Preferences > Performance
You could probably even check the MaxThreads settings and drop it down if it’s maxed to see if that helps. There are other settings in there that might help (like turning off MultiDraw) but you’d have to check to see what each does. Don’t forget to write down what the settings are before changing in case you need to change them back.
Working on something at moment so using 32 bit.
